01-13-2009, 03:24 PM
ca
Cobra Make, Engine: CRII with a Stroked Windsor
Originally Posted by capteddie
DV
I talked to Enzo at Finishline and he said that if my pulley setup from March pretty much replicates the original pulley setup, than that expansion tank would work. Looking at pictures of my setup compared to others that don't appear to be running March pulleys, mine and theirs look pretty much the same.
I think I'm going to order one of the tanks and bring it over on my next trip and you and I can mock up the tank and see if it will work. If it will, we can then figure out the hard lines. I'm pretty jammed at work until the end of the month, so I was thinking on coming over on 2/7, if that works for you? Maybe the temperature will cooperate between now and then (its -2 on this side of the lake today) and we might see some paint? ?
Cheers!
I have the march pulley set on my motor and that tank.. Absolutely no problem with that. Other problems with the tank but not the pulleys..
