  #677 (permalink)
Old 01-13-2009, 03:58 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Ed,
March Pulley systems usually create a problem with the "Puke" tanks because most guys run the "high brackets" with the alternator up high on the right side and the cross pulley-belt on the other causing an interference between the belt and the Puke tank. You do not have that problem.
Don't know what other problems could be unless the mounting for the tank is a problem?
DV
