Originally Posted by Merv and Sharon
There is a lot of advice on the internet and in the lubrication guides for the T5. What is experiences have you guys had with different kinds of lubricants for the T5? The manual says Dextron II or III. Others suggest Castrol Syntrans.
Merv
The correct
oil to use depends whether it is a world class or non world class. World class with fiber blocking rings uses only ATF, non world class with brass blocker rings uses 75~90 weight.Using 75~90 weight in a world class will destroy the blocking rings.
