Old 01-17-2009, 03:35 AM
boxhead's Avatar
boxhead boxhead is offline
I drilled a hole in my water pump assy (or is it the timing case) and threaded it with a 1/8 NPT tap, screwed the sensor straight in.
There is a flat section on the pump that points straight up, it is where Mike has modified and fitted his coolant filling point.
Cruising in 5th
