Old 01-17-2009, 09:22 AM
wycobra's Avatar
wycobra wycobra is offline
Cobra Make, Engine: Classic Roadsters 351W stroked to 427
DV, This is EXACTLY the problem I've run into!! When the 4.1122 mounts are set onto the CR frame mounts more than half of one the mount is not supported well. I knew that this couldn't be right. Just to make sure I modify the correct side--Did you modify the left or right frame mount?? ---Does the longer portion of the right frame mount go the the rear of the car for proper engine placement. Convinced that the motor mounts were wrong, I already returned them to Jegs, but I am going to Casper today and will see if an Autozone store has them. DV, could you still e-mail me just two photos - the left and right side of Ed's mounts in the car. It would add to my piece of mind that I am placing the engine in the correct location on the frame. Oh well, these little "glitches" in life help add to our "distinguished" gray hair appearance .....Thanks a bunch!!! Mike
"If Things Seem Easy and Under Control, You're Just Not Going Fast Enough!" Mario Andretti
