Old 01-17-2009, 09:34 AM
tcrist tcrist is offline
wycobra,
Bolt your engine and trans in the frame using your best guess on the mounts. Then bolt on at least one headder and sidepipe. If the bracket on the rear of the sidepipe aligns with the mounting hole in the frame then your going in the correct direction. The bracket that does not fit up correctly on the mount would be the one to modify. I was lucky and got the correct ones from CR. Once I knew they would work I welded in gussets on both sides of the angled piece for strength. Does not leave much room for a wrench, just enough. The way they were designed, I was concerned about them flexing.
Terry
