You said, "...Crank it and nothing..." Could you clarify that a little? Did it actually crank...or do nothing? If it didn't even turn over I would look at the battery ground first, then the ignition switch. If it turned over but did not fire, check the easy stuff first, power and ground on MSD box. The 2 wires on the coil, inside the distributor cap/center contact. Do this easy/cheap stuff first...then start spending $$$$..
SPFWiringDiagrams@Comcast.net
Reason: spelling
