Old 01-17-2009, 06:41 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The voltage stabilzer drops the voltage thru the fuel sender down to 10 volts. If you try and run the system at 12 volts, every time you turn on a large power user, like headlights, fans, driving lights etc and the voltage drops, your gas gauge would register incorrectly. Not an expensive item to replace...Call Mike E. at Dynamic.
SPFWiringDiagrams@Comcast.net
