01-17-2009, 10:12 PM
Cobra Make, Engine: SPF#0760
Well, if you say the powers & grounds are good...both at battery and by starter....I'm thinking coil, MSD box or ignition switch.
Go to the MSD website and find the coil test information.
Simple test with a volt/Ohm meter....
You can also find the test procedure there for the MSD box, also quite easy to do. Get thru that testing first. Costs nothing but some time...Did you look at the rotor and center contact in the distributor?
SPFWiringDiagrams@Comcast.net
