Old 01-19-2009, 03:05 PM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Ooops, sorry the ebay link didn't work, I should've checked it &/or listed the ebay item number.
Anyway, Fred and Rick, thanks for the input; makes sense that it would be for a cam driven FI pump, which would've been used w/o a water pump on a drag strip car. Even if I were to make a cover plate for the hole over the cam, its probably not feasible for a street driven vehicle using a conventional water pump.
thanks again guys!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
