Old 01-19-2009, 09:36 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
the trick would be to find out if the material is "Magnetic" or not. -- also I would drop the oil pan and check for rubble.
The key here is MOST bearing materiel is NON magnetic and clings to the bottom of the oilpan.
also whils under there (oil pan off) you can check endplay and such to see if you have eaten something.
Steve
