Old 10-30-2001, 08:41 PM
mkcobra mkcobra is offline
Default boosters
well I have done afew other booster projects and the brakes arent to bad. you will need a booster setup, with master cylinder around 200.00 if you look hard you can find one that will match your brake pedal and then just reroute the brake lines but you will need a porportion valves. and of course hook up a vacuum source. fitting a booster into your space and running brake line are the only hard parts. the clutch i dont know of any boosters for clutch, they usually dont need them so i would check and see why this is so firm. clutch basket or some other componet may be to blame what type of setup do you have for a transmission.
later MIke
