Old 01-20-2009, 06:02 PM
J Persons J Persons is offline
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
This is common on FFR's that use a toggle switch to operate the turn signals. You are correct in that a powered converter is required. These converters are normally used when connecting a trailer to a vehicle that doesn't have a compatible taillamp configuration. Post you question over on ffcobra and someone that's done it will advise you on the correct hookup.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
