I have run the same 505 inch, 676 horsepower FE engine on a dyno with both multiport EFI and a carb. Documented in Hot Rod magazine in 2004.
Same intake - a converted Dove single four barrel. We never touched a thing on the package - unbolted the throttle body and bolted on a 950HP, unplugged the injector wiring from the harness and hooked up fuel to the carb.
Based purely on airflow the EFI throttle body should have won. It didn't. A statistical dead heat - but the carb had single digit higher peaks on both torque and horsepower.
Testing done at Wheel to Wheel Powertrain - at the time one of the foremost EFI tuning facilities in the country. The EFI is better at almost every non-WOT and transient driving parameter - but peak power is not one of them.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
