  #39 (permalink)
Old 01-21-2009, 05:48 AM
Barry_R Barry_R is offline
Single plane 4150 flange
A/F was monitored in both cases via the O2 sensors in the exhaust.
Timing was identical - the FAST system was still plugged in and running ignition and some data could still be retrieved to back up the dyno - obviously not fuel.
The Weber deal would indeed be different. Most if not all carbed Weber deals suffer from inadequate airflow - no shared volume from the non-existant plenum. Ford's abbreviated Boss 302 IR effort used two Dominators. Anything that adds airflow in an IR package will show a gain - but the gain is because of the additional air and not the management system.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
