Old 01-23-2009, 07:32 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
hello don
good to see you making progress. i had the above cam made by mike jones for a 406ci sb with 9.8 compression, he spec'd out more lift but was reduced for valve spring longevity.
your cam seems a bit mild, especially for the compression. a cam will make or break the deal, if what you have doesn't seem right, go with something else.
with a custom cam made by "someone good" you get ramp rates that let you turn the motor higher rpm from what i understand. i've heard over and over again, it's how the lobes are ground that makes a difference.
also the above was for efi, your carb may require different stuff.
good luck
mark
