Do not let it go, pull them & replace them. Go with 31 spline Moser axles. They will be the last set you will ever purchase for the car. 35 spline is way overkill & as stated previously, limits your posi set up options. I am running Moser 31 spline axles & Moser center section Detroit locker 3.70 gear in a massively reinforced 9" Ford housing. Putting the torque & horse of a blown 542 FE through it to Drag Radials. Not in the least bit concerned about hurting 31 spline Mosers. They'll take it.
Regards,
Mick
(Of The Troops & For The Troops)
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body; but rather a skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, WHAT A RIDE!"
