01-25-2009, 05:14 PM
The short answer is "Yes, you should replace it with a 2 gauge wire." Why? Because the 4 gauge wire gives you additional resistance under the heavy amperage draw of cranking. This results in a lower voltage to the starter, resulting in heavier amperage draw and increased internal heat in the starter. Bottom line: The cable is not likely to catch fire and melt, but the life of your starter will be shortened.
