Old 01-25-2009, 07:54 PM
jklehe jklehe is offline
Cobra Make, Engine: Backdraft Racing 00249 w/Ford Racing 351W/385hp crate motor, aluminum GT40 heads, roller cam & rockers, Mass-Flo fuel injection system. Chase car: '96 ImpalaSS
Jay, I did a pretty close search in the foot pedal area and no sign of a mechanical switch.
Bruce, I've got two electrical wires coming in to the underside of the front of the master brake cylinder, so I'm assuming I have the hydraulic brake light switch. As I mentioned previously, I noticed some fluid (hydraulic, brake) seeping in the area where the wire terminal come in to the master cylinder and so I suspect that's the brake light switch and that it's leaking and most likely bad.
It's going in to the shop in the morning for a new title inspection and I'll ask them to replace the part prior to doing the inspection which should fix the situation.
Thanks guys! joe
