Old 01-28-2009, 11:14 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
as i said above, cut the flange between the middle two pipes at the least, i cut between all flanges and use rtv. never had a problem with things loosening if rtv the bolt threads before insertion.
don't have to worry about the flange being straight. also, if aluminum head, the expansion is considerably more than a strap of metal across the side, leads to blown gaskets and loose bolts.
hth
