Old 01-28-2009, 09:17 PM
car4jim's Avatar
car4jim car4jim is offline
Cobra Make, Engine: Kirkham, 427 side oiler
You should be able to buy a wire harness that plugs into a connector to the left of the streering column under the dash. The truck should be pre-wired if you have a factory trailer connector in the rear. The wire harness is available at a trailer/RV supply retailer for like $15 bucks. Plug in and wire to your brake controller and your good to go!
