Old 01-29-2009, 04:19 PM
Default Give me a call, I will walk you through it
Sparks Give me a call. I will walk you through it to do. The trailer wiring is rapped up in the back of the truck behind the bumper. There is a red and blue wire, rapped in the front by the fuse block under the brake booster. You will still need to buy a brake controller box. There should be a patch cable in the truck for hooking up the trailer lights with a picture of the wires and what color they are. Give me a call, I can walk you through it. You will need a 7 pin connector and plate to mount it on the back of your truck. Use tow mode also and unless you are on real flat roads, stay out of 4 gear with the convertor on lockup. 732-254-3536 Rick L.
