Thread: 2x4 carbs "428"
Old 01-30-2009, 05:31 AM
Barry_R Barry_R is offline
I size these setups as if they were a single double pumper carb - ignore the vacuum secondary side. I would personally (this is just an opinion) run nothing smaller than 600s on a stock engine, and 750s on anything modified. The secondary barrels will only come in as airflow demands - they will not "overcarb" the engine, and their opening rate can be adjusted.
Normal universal type carbs will work. Some tweaks are needed for compatability with the reproduction linkage. The repro carbs will work well, but seem to be calibrated extremely rich - no doubt matching Ford's calibration from back in the proverbial day.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
