Old 02-02-2009, 08:53 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
I have a 514 in my SPF. I can sit in 100 deg weather and it stays under 200 deg. I put a high flow 180 deg thermostat in. The SPF's have two puller fans that are completely sealed in the front and rear, so everything the fans pull in, goes through the radiator and into the engine compartment.
What do you have the timing set at??
Scott
