There is an Allah...only three years!!!
Ok...same or slightly larger diameter as the reservoir tanks, just longer. Petcock at the bottom and a tube so we can attach a rubber line that will let it drain out below the frame (buy a cheap plastic Summitt one like JJ and I use and you'll see).
The top can be a threaded cap, but with a fitting to accept the line from the expansion tank.
Use the same mounting setup...we can either put it next to the reservoirs or on the passenger side (my expansion tank has the cap/pverflow fitting on that side...don't ask me why, you installed it just to make me feel special I guess, and no, I haven't installed that shiney sucker you sent me cuz I'm lazy).
Don't get fancy...KISS!!!
Feel free to etch "Jamo Dump" on the side.
Bite me.
