Driveshaft yoke removal from T5 tranny
Good afternoon.
There is a small tranny fluid leak coming from the tail shaft where the driveshaft yoke goes into. I suspect it is the seal inside the tranny tail shaft. I would also inspect the yoke for burrs, and similar deformation while at it. My question is, do I have to remove the entire driveshaft from the car or is it possible and easier just to remove the yoke end of the driveshaft and leave the main body connected to the read end?
If possible to remove just the yoke end, will reassembly be as simple? just reinsert, line up, and tighten? Then refill tranny with fluid.
thanks for the help!
