Don,
I would imagine the wind forces of 155 compared to 110 are quite substancial, so I understand your course of action. I eventually may have to adopt something similar, we'll see. You are correct in the fact that my seal is to the inside of the scoop. It just so happened that matched up with the size of the air pan, and the contour of the scoop may actually help hold the seal in. The front lip of the pan is about 1/4" from the lower opening of the scoop, thus no seal needed there. This season is, for the most part, over here in Ohio. Next summer, we'll see how it holds up in more taxing situations. So far, I'm very pleased.
Best of luck to you if you decide to build the "big box"! I'd love to see it if you do. Perhaps you could post some pix back here?
Regards,
Dave
