02-05-2009, 07:48 PM
UT
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
If the mass air flow sensor and the injectors are sized to match, it should run sweet after about 5 starts and 10 minutes run each time (for EEC to "learn").
Assumptions:
1. EFI Distributor wiring as per flyboy1997 mentioned.
2. Stock Ford EEC as recommended by Chris at Mass Flo.
3. Grounds all installed.
4. Initial timing w spout out at 12-14 degrees
5. O2 sensors wired correctly.
6. Fuel pressure set at 38 PSI or as recommended for your injectors.
7. IAC installed and wired right. (Idle Air Control valve)
