Old 02-06-2009, 11:23 AM
barabar barabar is offline
Let me explain,
I'm trying to accomplish 3 things, Street/Strip/Roadcourse. The HP is around 1000hp, 700hp 521 cu in cj BBF 4 BOLT NA and 300hp NOS to be stage in at 150hp 3rd and 150hp 4th gear. (please don't ring in and tell me you can only get 450hp to hook up) You can get as much hp as you can control. Remember, IT IS BETTER TO HAVE THE HP AND NOT NEED IT THEN TO NEED IT AND NOT HAVE IT.
THE FRAME--I've silhouetted the rear portion of the frame with 3/8 steel, also removed the1"X1" rear frame braces and tacked welded in 2"X4"X3/16" and countless gussets. (see pictures) Also ran 2"X2"X3/16" down each side of the frame, inside the square tubing I ran round tubing to accommodate electrical on one side and fuel on the other side. (will send more pictures) I have reinforced the rear cross member (see pictures) to avoid fabricating a cross member behind the engine.(wait and see).
I hope I've answered your questions. Who am I speaking with? Mike.
