Originally Posted by brent110672
Sam, I had ERA bond the body to the frame. I did the rest. Now the question. I don't want to put the exterior rear view on the fender.
The screws on the windshield are not US or metric. Probably english wentworth (sp). Where would I find Them?
Well, the comp cars used the Raydot mirrors mounted on the windshield frame ...
I just laid some blue painter's tape down and measured twice per the manual, then bit my lip and drilled the fender
Use the correct drill size, and then go easy when inserting the screws, backing out every 1/2 turn as you go. Same for the dash mirror.
Glad you found the screws, I think they went to SAE threads on the later cars. Peter calls them "witless" screws
Sam
