Old 02-06-2009, 06:44 PM
Ronbo Ronbo is offline
Cobra Make, Engine: Kirkham #570 w Shelby FE
Should work, other option is to flare the tube and use a tube nut and sleeve. Be carefull as AN uses a 37deg. flair not 45 like most standard flair fittings.
You could also use a brass compression to pipe thread fitting and then screw in a AN to pipe adapter as well.
