Thread: New guy..
Old 02-06-2009, 08:19 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
If you haven't a lot of building knowledge look for a kit that basically bolts together.....some have to have alot of parts made. don't always take the cheapest option it can cost you in the long run..don't be in an almighty hurry to build it... check out alot of cars first you'll pick out things you like... Talk to people and learn from others mistakes instead of making them yourself..You will change your mind on colour 10 times before it is ready for paint....Don't rule out building a DRB 540 if you want a bolt together car Check it out on other thread
Best of Luck
Cheers Mark
