I've had a few Wells Cargo trailers and some of the reasons why I choose them over Pace or other brands
Frame rails are retangular tubing, nor an channel iron
Door locks are robust locking lugs that also prevent up/down movement of the door
Beaver tail rear floors that allow easier loading---you probably won't need to elevate the tongue to get car chassis to clear floor hump
reccessed side door opening--like a built in step--eases entry/exit
Diamond plate rock guard on front of trailer
Retangular tube tongue rails make using equalizer hitch similar
Enought interior height that you can stand up
E track available mounted from factory
Side vent system that works to evac fumes while traveling
Interior lites avaible
Colors optional
Can spec where you want the axles/doors for balance
I now have a Featherlite gooseneck---they are framed with extrusions and are sort of a mono type structure
