the edelbrock heads and Erson rocker assy are 50 lbs lighter than the iron heads/stock rocker assy---the 750 carb probably won't gain you any hp but a larger 950-1000 4v will
both these engines used our custon designed solid flat tappet cam for the SOUND and of course had forged h beam rods and Diamond forged pistons
we also used the edelbrock 427 heads with the larger valve sizes
