wow macvabch that is good, that much pwr down low and lightwt clutch is gonna be tough.
i have a header design program that will tell you what size exhaust pipe and collectors work best that is pretty accurate.
the program needs:
ve %, bore size, stroke, rod length, peak hp rpm, comp ratio, valve head diameters, valve lifts, dur. @ .050, degreed intake and exhaust centerline, lobe center angle, and the length of exhaust port from valve face to manifold mounting surface centerline.
if you post this i'll input and send you the data.
good luck.
--- Single Primary Pipe Specs --- for 406.268 CID from 4600 to 7100 RPM
Diameter= 1.817 to 1.942 Length= 29.7 to 32.5 inches long
--- 2-Step Primary Pipe Specs ---
1st Dia. inches= 1.817 Length= 14.9 to 16.3
2nd Dia. inches= 1.942 Length= 14.9 to 16.3
--- 3-Step Primary Pipe Specs ---
1st Dia. inches= 1.817 Length= 9.9 to 10.8
2nd Dia. inches= 1.942 Length= 9.9 to 10.8
3rd Dia. inches= 2.067 Length= 9.9 to 10.8
--- Header Collector Specs (Conventional Straight Tube) ---
Diameter= 3.576 Tuned Lengths= 17.1 best and 8.6 or 34.2
--- Header Collector Specs (Megaphone or Diffuser Cone Shape) ---
Diameter= 3.076 taper to 3.576 Megaphone/Diffuser Length= 17.1 inches
H-Pipe= 17.1 X-Pipe= 68.4 distance behind end of Primary Tube ends
-- Total Exhaust System Tuned Lengths (Primary ends to TailPipe end) --
Best HP/TQ Tuned Collector Lengths= 17.1 , 34.2 , 68.4 , 136.8 inches long
Worst HP/TQ Loss Collector Lengths= 25.7 , 51.3 , 102.6 , 205.3 inches long
Note=> measured from where the Primary Pipes end inside the Collector to
the point the tailpipe exits into the atmosphere.
Note-> all Pipe Diameters are OD and based-off .0625 inch Pipe thickness
---- Primary Pipe's Harmonics ----
1st Harmonic = 131.0 inches long ... typically never used
2nd Harmonic = 49.7 inches long ... longest recommended
3rd Harmonic = 29.7 inches long ... highly recommended , best Torque Curve
4th Harmonic = 20.7 inches long ... shortest recommended
5th Harmonic = 15.6 inches long ... typically never used
6th Harmonic = 12.2 inches long ... typically never used
7th Harmonic = 9.9 inches long ... typically never used
8th Harmonic = 8.2 inches long ... typically never used
---- Collector's Harmonics (includes Intermediate, Muffler , TailPipe) ----
1st Harmonic = 136.8 inches long ... longest with Mufflers and TailPipes
2nd Harmonic = 68.4 inches long ... longest recommended with Mufflers
3rd Harmonic = 34.2 inches long ... more bottom-end Torque
4th Harmonic = 17.1 inches long ... highly recommended , best Torque Curve
5th Harmonic = 8.6 inches long ... reduced Torque , more top-end HP sometimes
6th Harmonic = 4.3 inches long ... reduced Torque , not recommended
looks something like this.
