Past the initial lamp test it should not be on.
Short the test pin with a paper clip and count the flashes...
'Bout everything you'd want to know about Ford EFI systems is here:
www.fordfuelinjection.com
To clear out all existing (old) trouble codes, disconnect the battery for a few minutes. Then run the motor and get the latest codes. (assuming the check light comes back on)
