Old 11-02-2001, 06:53 PM
DavidWard's Avatar
DavidWard DavidWard is offline
Cobra Make, Engine: FFR 1204 With Stack Injection
Send a message via ICQ to DavidWard
Don't know the part #, but you can get the steel gear from Ford. It comes un-bored, however, so you will have to get a machine shop to bore it. I'm running the 8582 distributor, which is the same unit that you have except shaft is shorter to fit the 302. MSD sent me two gears, the first was cast, and the second was steel, but wrong diameter. I went with the Ford gear, and it still looks good after 13,000 miles. Ford gear was $11 when I bought mine.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
