Old 02-11-2009, 05:45 PM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by Trueoo7 View Post
Thinking about changing over from a HEI distributor (Ford 302) to a MSD system. HEI is showing wear after about 5000 miles, and not sure of the brand. I've searched here on the forum and see people have had a lot of problems to the point they carry backup pieces and systems with them. The cost difference is about 3 times the price not including the spare pieces. What are your impressions as to the added performance, if any, and the reliability. Not looking to race down the 1/4 mile but don't want to break down or have to be troubleshooting this thing constantly either.
Thanks
There are some nice performance HEI replacement distrbributors. If your 302 is close to stock this might be a good way to go. Some of these units offer adjustable advance curves which might allow you to get a little better performance from your motor.
If you have a higher compression motor, buzz it to RPMs above 5,500 alot, or are using nitrous, turbos, or a supercharger, then you should consider a full-blown setup from someone like MSD. I have MSD distrbutors, boxes, coils, and wires on two pretty radical street driven motors (one blown and injected, the other a 482 ci injected stroker). I've found MSD's stuff to be top notch from a performance and reliability point of view IF the parts are properly installed. I like the MSD billet distrbutor, their Digital-6 Box and their small blaster SS coil for a hot street setup. I have not had any problems with the MSD systems on either car. Check out my gallery for some pictures of this stuff if you're interested.
- Fred
