Old 02-13-2009, 06:16 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Thanks for all your input I really appreciate your opinions,
First let me say that this is the first time I have every used any kind of assembly lube on a cylinder wall and it was suggested by a very reputable builder. I skimped on that procedure because I took a very small amount of the lube on a white rag around my finger and put about a thin 1" circle about mid way up the cylinder. In the past I have only used WD 40 or a light coat of 30W motor oil during the piston assembly.
I got my oil pump in yesterday and it had some damage to the input shaft so I called Summit and they immediately sent my replacement out and arranged to pick up the damaged one. They were very appologetic for the problem. I personally think they are great to do business with.
For now everything is on hold until I get the last couple of parts to button everything up and take it down to the dyno. Back in the bag it goes.
Clois
"Let's roll"
"Be part of Something Good
