Old 02-14-2009, 04:54 PM
Rick Parker's Avatar
The lateral link must be able to travel through the entire pivoting arc without restriction. Does the other side have this same appearance? 2 solutions: 1. Convert to high quality rod ends with threaded tubes and replace upper and lower links. 2. Remove upper rectangular link and taper the end and weld a cap over the removed section, this is above the pivot point.
Rick
