The determining factor here is the cam gear. You don't want both gears made from the same metal. If the cam gear is iron, then you want a steel distributor gear. If the cam gear is steel, then you want a cast iron distributor gear. The roller cams from Ford use a cast gear, so a steel distributor gear is needed. Some of the after-market cams use steel gears.
David
http://members3.clubphoto.com/david251117/guest-1.phtml
