Old 02-16-2009, 05:59 AM
Mac VABCH's Avatar
Mac VABCH Mac VABCH is offline
Cobra Make, Engine: BDR #250
Gregg,
I struggled with this for a couple of years. I had the exact same conditions that you are having. For pumps I used Mallory from Summit Racing, they are quiet and don't drawl much current. For the high pressure pump I used a Mallory 4060EFI pump it has a max pressure of 55 psi, flows 60 gallons per hour (227 liters per hour) and only draws 7.5 amps. For the low pressure pump I used Mallory 4070M w/a max pressure of 6 psi, flows 70 gph (264 lph) and only draws 2.5 amps. I am very happy with theses pumps as them a quiet, I mounted them on rubber grommets. They are being used on a 590 HP engine up to 7000RPM with no fuel starvation problems. With the low current draw I ran them on the same circuit in parallel with a 12 amp fuse. Hope this helps.... Mac
