Originally Posted by Aussie Mike
From the look of your chassis the "Direct shift" will come out almost in line with the steering wheel. Not sure what you mean with the gaffer tape but my shifter comes out on the forward inspection cover. You can see the cover on your box just under the first cross member back from the front edge of the tunnel sheet metal.
Actually you're right Mike. In my mind you were using the location at the rear of the box. I guess I could relocate that crossmember and get the box modified... will give it some more thought.
