Old 02-19-2009, 05:09 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
I considered under the dash for the bottle, but wanted to make for an easy inspection should I want to track the car.
Routing the tubing from the trunk is tough. Having to poke holes (take a deep breath...) and getting the tubing through the frame holes along with the fairly massive battery cable gets a little hairy.
Good point on the direction of the cockpit nozzles. They spray 120 degrees, so I should be able to get under dash and lower leg coverage.
DD
Dangerous Doug
"You're kidding, right?"
