Old 02-22-2009, 01:11 PM
Power Surge's Avatar
Power Surge Power Surge is offline
Originally Posted by KarlCSX2498 View Post
Hey Sal, the goal is as close to original appearance as possible. I have the FE, toploader, original style center section, CSX4000 tubular steel suspension, 42 gal. tank from Acton Custom, alloy body and original side pipes. I did use the wilwood brake calipers & alloy radiator, I guess you can call those two items modern upgrades.
Dark Blue or black paint, no stripes.
thanks jeff, will see you at NJ with this car.
regards, karl
That's what I figured. My car is the same way. I like it to look correct on most details, but I also like having upgraded stuff that makes it better or safer to drive.
If you need any help or advice on making non-original stuff look original, shoot me a message sometime. On your radiatior, you can paint it with Eastwoods radiator black (semi gloss finish) and then put a repro Serck tag on top and it looks much more correct (what I did with mine).
Sal Mennella
