Thread: MSD Ingition
Old 02-24-2009, 06:58 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
What gear ratio do you have in the rear end? The higher spark from the ignition module might help a little at low end but they are mostly a big help at high RPM. I used to disconnect mine once in a while to see if I could tell much difference and just driving around town I hardly noticed it and probably wouldn't have if I didn't know I had it disconnected. But I sure did notice it when I started getting up into the higher RPM range. And as you said, maybe have a good mechanic set up your carb and timing for what you want to do.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
