Summit sells a kit for around $100, CompCams about $140, but my advice is find someone who has done it, has a kit, do it together and buy the beer. Unless you're going to build more engines the only part of the kit you're likely to use again is the run-out guage. The heads should be on so you can find TDC to set your wheel up.
