Old 02-26-2009, 04:32 PM
stumpeater's Avatar
stumpeater stumpeater is offline
Cobra Make, Engine: Harrison, VE L98 + T56
Default Petrol Filler Pipe
G'day Have been attempting to instal the filler pipe to the tank, in my Harrison the problem is the only thing the tank pipe (alloy) and the hole in the fibreglass have in common are they are both on the same side of the car, they do not line up at all. I have an "unleaded " filler and cap from a Volvo that looked like it might come close, but no luck. I need to know if there are flexible 50 mm pipes for this purpose, alternatively I may be able to use a 90 and a 45 degree bend in Turbo Silicon inter-cooler pipes. Are there any problems with silicon and petrol? (I doubt it, but you never know) Thanks, Peter
Life is what happens to you while you're busy making other plans...JWL
