Re Sketches
Fuel Pump should be mounted behind the fuel cell. A fuel pump likes to PUSH gas, it does not do that great a job of sucking .....
Fuel pump should be mounted lower than the fuel cell with the pick-up mounted on the bottom. Again, its easier to PUSH rather than suck the gas.
Does fuel cell have a dedicated vent?
Where is fuel filter?
Avoid any and all sharp 90 degree fittings.
Minimize the amount of fittings inside the trunk. The ideal number is 0.
Never run fuel line inside passenger compartment.
Warren
