At some point you should just run the negative on the battery directly to the block and have a jumper from the block to the frame.
No-Lox and star washers on all connections.
(copper anti-seize is a good substitute for the No-Lox)
Fiberglass or not, relying on the frame for ground connections will provide hours of irritation.
